Starter motor and solenoid
Old 22-03-2008, 05:28 PM
leeadams
leeadams's Avatar
Default Starter motor and solenoid
Just a quick one, am I right in believing that you can not just change the sloenoid on a 2wd cossie, as it is part of the starter motor?
Thanks
Old 22-03-2008, 08:51 PM
jon@work
jon@work's Avatar
I doubt you can buy just the solenoid by itself, but you certainly can take them off the starter and change them.
Old 23-03-2008, 08:13 AM
You can buy just the solenoid, and as above says, it is held on with two through screws with philips/pozi drive heads.
The unfortunate bit is they are BOSCH solenoids so stick anyway, although LUK(lucas, etc) copy most BOSCH stuff.
bobsworth
77
24-03-2016 09:30 PM
A.t.p
23-10-2015 07:54 PM
cossie362
11-10-2015 03:53 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
marky_g
12-09-2015 04:26 PM
Quick Reply: Starter motor and solenoid
