How do i change a rear diff mount????
Old 17-03-2008, 01:27 PM
BA
BA's Avatar
Default How do i change a rear diff mount????
As above, on a 2wd saff cossie, changing from standard mount to Group N, any help/ advice to get the old one off would be much apprieciated!! thanks!!
Old 17-03-2008, 03:53 PM
rinus_2005
rinus_2005's Avatar
Notthing special, first did the 4 bolds to chassis, then the 2 that are connected to the diff. The arb should not give much trouble to work around.
Succes
Old 18-03-2008, 08:23 AM
As said quite easy, just make sure to support car(chassis) on axle stands, AND support the diff weight,with jack/wood or it will jump down.
Plenty of coppaslip on the bolts when putting together.
Old 18-03-2008, 01:38 PM
BA
BA's Avatar
thanks for the replies.... all bolts out now but the mount still wont come off the diff!!
Old 18-03-2008, 07:14 PM
If you have defo taken out the TWO bolts that go through the mount to the diff rear casing, then it is just a bit of differential(metal) corrosion holding it.
You need an IRISH SCREWDRIVER, and whack it not too hard though.
Old 18-03-2008, 11:40 PM
BA
BA's Avatar
thanks, will give that a go....
Old 19-03-2008, 07:02 AM
KSA-Cossie
KSA-Cossie's Avatar
Irish screwdriver.
09-10-2015 07:38 PM
siscossie
27-08-2015 09:27 PM
cameron2
25-08-2015 07:18 AM
track.focus'd
12-08-2015 05:53 PM
xr4x4rs
06-08-2015 09:03 PM
Quick Reply: How do i change a rear diff mount????
