Fan Switch :(
Old 12-03-2008, 05:13 PM
SWIFTY
SWIFTY's Avatar
Default Fan Switch :(
As some of you may or no my car overheated the other day and im sure its the fan switch at fault, as when i take the plug of it an join them together with a wire they always come on, so i have now taken the switch off to get a new one but i wanted to test it first so i boild the kettle an put it in the hot water an nuffin so i thought gerat easy fix, but then i put it in a pan an put it on the oven and after a will it worked then didint then did.
so my qestion's are:
what temp should they work???
should the kettle make it switch??
does this sound like i have a faulty switch an should be ok with a new one??
thanks
(sorry about spelling??
Old 12-03-2008, 05:46 PM
SWIFTY
SWIFTY's Avatar
just noticed the fan switch is not the nomall type does any one no what its off thanks
Attached Thumbnails Fan Switch :(-dsc00076.jpg   Fan Switch :(-dsc00073.jpg   Fan Switch :(-dsc00074.jpg   Fan Switch :(-dsc00075.jpg
Old 12-03-2008, 06:07 PM
charlie luciano
charlie luciano's Avatar
Right ok, iirc the fan switch should kick the fans in at 87-88 degrees, if you fit a new switch and the fans still don't come in and car continues to overheat its more than likely that your rad is blocked and restricting the flow of coolant,
to test when car is at running temp, feel the rad top n bottom, if top is red hot and bottom is cool its new rad time
and I don't know what switch that is but it aint a cossie one
Luciano
Old 12-03-2008, 06:18 PM
Just put a new cossie one on for the price, don't know what the one pictured is off, but get part number and check at fords if you want.
The fans will typically come on 5-8 C ABOVE the max temp of the stat, as otherwise they will fight all the time.
Old 12-03-2008, 06:39 PM
SWIFTY
SWIFTY's Avatar
I would put a normal cossie one bk in but dont want to mess with the plug
so it should work with the kettle???
the rad is new an so is the cars wireing
Old 12-03-2008, 07:11 PM
broos3
broos3's Avatar
Location: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Yes it should have worked when you boiled it in the kettle. Change the switch and see. Flush the rad out with clean water before you put the new switch back in. Just to make sure its nice and clean.
Bruce
Old 12-03-2008, 08:57 PM
kosienutter
Last Time, Get Off PF FFS
kosienutter's Avatar
just to let u know i had a new fan switch fitted to my 4x4 it only costed 11 quid.
Old 13-03-2008, 10:47 AM
AndyPen
AndyPen's Avatar
Like many others I've fitted an overide switch and a temp gauge to be sure )
Old 13-03-2008, 12:39 PM
bpspa
bpspa's Avatar
I ahve just rewired mine as well putting in an override switch
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
rsguy
44
29-09-2015 03:29 PM
cossie330
27-09-2015 04:13 PM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: Fan Switch :(
