xr4 coilovers and wheels???
Old 10-03-2008, 03:58 PM
paul302289
paul302289's Avatar
Default xr4 coilovers and wheels???
can anyone help? i've just fitted gaz coilovers to my xr4i and am having a bit of trouble gtting wheels to fit. i've got some 17 inch wolfrace but they rub on the front shock, does anyone know the best size wheels that will fit, aftermarket or off of another ford, done a fortune so far so would like the cost kept down for now and get something tasty in the future?
Old 10-03-2008, 04:04 PM
STUCOS
STUCOS's Avatar
Paul,am i guessing tyre/wheel rubs on spring seat,if so i had same problem with my 3dr on 17 in wheels,raise spring hight or run shorter springs
cheeRS stu
Old 10-03-2008, 05:59 PM
paul302289
paul302289's Avatar
the rim is actually rubbing on the shock. that is without a tyre on the wheel. i dont think i can raise the spring that much to clear the tyre without it looking like a paris dakar racecar. also the rim is too wide to space the wheel out, if i did it would look like carlos fandago super wide wheels. i'll give gaz a call to see if i can fit a sorter spring but i doubt it as they will need to be stiffer so the ride will suffer, appparently they will be harsh as they are. cheers, Paul
jessie_rs
62
06-08-2019 09:27 PM
S3an
26-09-2015 11:39 PM
S3an
13
13-09-2015 10:01 AM
yorkie92
06-09-2015 05:34 PM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: xr4 coilovers and wheels???
