What offset do I need to cover 330mm 6 pots
What offset do I need on the wheels to clear 330mm 6 pot wilwoods.
My current wheels are 17" with a 37 offset and they don't go on, I'm thinking about going for 18's but do I need a smaller offset like 33 as I have the chance of some cheapish but they have an offset of 38.
If 33 offset is used with 18's will it cause any clearance broblems with the wheel arches etc, the car is lowered by 30mm and I would use 215/35 tyres.
N
N
Some wheels will have more clearance than others, i know some of the OZ wheels have some deep clearance on the spokes, apart from that it will be a case of measuring the caliper to hub space and then going from there. On mine i got 335mm six pot hi-specs and some 8x18 Fox rs5's et35 and they clear no problem
Resident Wrestling Legend
speak to martin "reyland"
i know he sells the comp mo stuff and can get them ordered in specific offsets if you need them and can probably tell you what you need
the other way is to find out what size spacer you will need to get your wheels to fit and then get a wheel with that offset
Judging by your sig I would hazard a guess and say your car is 2wd, 2wd & 4x4 are a different kettle of fish when it comes to fitting big stoppers, ie the 4x4 is a right pain in the harris,
Luciano
saff is working!!!...atm
as said above 2wd and 4x4 are different.....my wheels fit on a 2wd with the same brakes as mine,but i had to get spacers.......the bells are a different fit/shape
Hi
Mine is a 4x4 and I would need huge spacers as the spokes curve in a lot, I measured with washers on the studs and at about 12mm they were still catching, if they were 18's or the spokes were flat would probs get away with 6mm but as is the wheels will have to be replaced.
I would love comp mo's but don't really have that sort of money to spend at the minute so I'm looking for something more suitable secondhand.
