4x4 cosworth over feuling any susjestions please help
Old 07-03-2008, 12:26 AM
CRAIG HAYTER
CRAIG HAYTER's Avatar
Default 4x4 cosworth over feuling any susjestions please help
I Having A Problem With A 4x4 Cosworth Basically Was A Non Runner, I Have
Checked And Rectified Spark At Plugs, Swapped Map Sensor, Swapped Crank Sensor And Tried Another Fuel Pressure Regulator
I Managed To Get It Started But There Is Serious Over Fuelling Black Smoke.
When I Un-plug The Injectors & Start The Engine It Runs Good For 2-3 Secs
So Tried Injectors I Know Were Just Serviced And Ecu For Same But No Difference. If I Reduce Fuel Pressure Regulator Pressure To Below 1 Bar It Runs And Idles Much Better But Still Over Fuelling (black Smoke)
Any Suggestions Please cheeRS for taking the time to read this
Old 07-03-2008, 07:01 AM
Water temp sensor may be.I had a fault on my cossie when the engine was warm it used to misfire and chuck loads of black smoke at the exhaust. I changed the sensor and its been ok since.
Old 07-03-2008, 05:33 PM
If you know it was running fine before being a non runner, then I would as said change the CTS.
Another thing to check is the PHASE sensor alignment, as unless it is bang on it will overfuel big time all the time and belch soot out as well as drive like a bag of poo, if this is correct, change CTS and set CO to 2.5%
Old 07-03-2008, 11:02 PM
Jake_N
Jake_N's Avatar
Deffo water temp sensor
Old 08-03-2008, 08:04 AM
STUCOS
STUCOS's Avatar
Could be faulty map sensor,check air pipe to map sensor,were's you shit hot o a mechanic brother when you need him
cheers stu
mk3 fiesta cosworth
23-08-2015 10:31 AM
MARKYMARKONE
20-08-2015 12:55 PM
cossie4x4
14-08-2015 06:29 PM
14-08-2015 07:29 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: 4x4 cosworth over feuling any susjestions please help
