Which adjustable tca's?
Old 27-02-2008, 12:52 PM
wildheart
wildheart's Avatar
Default Which adjustable tca's?
Im after some adjustable tca's but been advised to get some based on original ford items.
Does anyone know who sells said items?
Not after cheap ones such as Compbrake before anyone says about them lol.
Old 27-02-2008, 06:40 PM
NUTS RuS
NUTS RuS's Avatar
If you want to go and buy some from Ford wildheart I can convert them for you.
Old 05-03-2008, 02:58 PM
wildheart
wildheart's Avatar
Cheers mate,Will keep you in mind.
Old 05-03-2008, 03:06 PM
Sticky.
Sticky.'s Avatar
Whats wrong with the Compbrake ones
Old 05-03-2008, 04:02 PM
Ridgey
Ridgey's Avatar
Nothing
Old 05-03-2008, 06:15 PM
cossie604
cossie604's Avatar
More to the point...when did Ford suddenly get a stock of 3dr front lower arms in???
Old 05-03-2008, 10:44 PM
chrisreid
chrisreid's Avatar
has any1 had any probs with compbrake ones or are they just cheap crap that wont last. Its for a track car not road so will be getting total death 24/7
Old 05-03-2008, 11:11 PM
NUTS RuS
NUTS RuS's Avatar
Why not take the advice from the last time you asked ?
https://passionford.com/forum/ford-sierra-sapphire-rs500-cosworth/221826-comp-brake-adj-tca-s.html
FYI we both use the same importers (TMS) and now import more units into the UK than they do.
I personally still have a zero percent returns rate on them over the last 2.5 years despite all these so called "tales of woe"
If I double the price tomorrow will you 'think' your getting better value ??
Tony
Old 06-03-2008, 10:19 AM
chrisreid
chrisreid's Avatar
I just have heard stories bout using the tca's with the small ball joints and that its bad news. nvr heard a bad thing bout compbrakes just wanted to be sure be4 buying
Old 06-03-2008, 11:05 AM
Sticky.
Sticky.'s Avatar
Originally Posted by Dave Ridge
Nothing
Thats what i thought.
Old 06-03-2008, 04:30 PM
KSA-Cossie
KSA-Cossie's Avatar
Seconded.
Old 06-03-2008, 05:35 PM
wildheart
wildheart's Avatar
Same here.
But if no one has had a problem with them then maybe i'll give some a try.
Old 06-03-2008, 09:13 PM
chrisreid
chrisreid's Avatar
fink i mite do the same with a set of compression struts aswel
Old 07-03-2008, 02:02 PM
florent78
florent78's Avatar
no problem with tca
and will by quicly the compression strut
yatta
21-05-2016 10:31 PM
mk1turboestate
02-12-2015 08:31 PM
Fezman1
02-10-2015 01:22 PM
IainRS1700T
25-09-2015 06:44 AM
Mark V8
13-09-2015 09:34 AM
Quick Reply: Which adjustable tca's?
