Disconnecting iscv
Old 23-02-2008, 09:58 PM
Default Disconnecting iscv
Will it do any harm to the engine having it disconnected. Im on trying to find what is causing a fault on my car when its cold so i have had the iscv disconnected this morning to try and elimanate that. I noticed the the idle was a bit lower this morning on the way to work at junctions. Then when i came home it was idling higher. Is this a faulty throttle switch or is this normal.
Old 24-02-2008, 04:33 PM
Once the car is warmed up, the car should be idling on it's base setting, about 850/900rpm acheived with the screw on the underside of the throttle housing, with ISCV disconnected, lights etc OFF, then when you reconnect the iscv the revs raise a few seconds then go to base setting.
The iscv is to raise the revs at idle when loads such as lights etc are applied(alternator drag).
No it will do no harm not having it connected you just lose the fast idle facility.
Old 24-02-2008, 04:37 PM
I started my cossie up from cold this morning. The ISCV was still disconnected and the idle was really low. So i plugged the ISCV back in and the revs were going up and down for a few seconds then it sorted itself out. I took the ISCV out used brake cleaner to clean it and used service lube and lubricated. I refitted the ISCV and the revs were still Going up n down. Could this be a faulty ISCV.
Old 24-02-2008, 07:02 PM
It COULD be but unlikely, as the fact that it is going up and down shows it is actually moving.
More likely to be running a bit lean, so get co checked and set to 2.5% CO.
Old 24-02-2008, 07:09 PM
trevCOSS
trevCOSS's Avatar
sounds like to me the first thing to do would be re set the base idle and go from there, however worth getting it checked out for fueling as above
Old 25-02-2008, 06:27 AM
I have previously put in another question from the same author about setting up the base idle first, but he posted quite a few times in different sections.
Old 25-02-2008, 06:55 AM
I know it is running rich cause i took it to a bloke how deals with proformance cars and he has an escort cossie rally car. He set the co mixture (on the side of the ecu). Last year for the mot i had to turn the mixture down to get it though the mot then i put it back to where it was. Is it ok for the engine to be running rich or would you recommend setting the fuel mixture to where it should be,normal.
Old 25-02-2008, 08:07 AM
KSA-Cossie
KSA-Cossie's Avatar
Run too rich is bad for the engine m8 get it set up who knows you may even gain more power .
Old 25-02-2008, 03:06 PM
It needs sorting out by someone who knows what they are doing.
It is complete crap that they need adjusting down for MOT's then adjusting back, if running correctly they will fly through the MOT, the only downside they have is the antique of an ecu!!
Old 25-02-2008, 05:41 PM
Im want my car setting up later on in the year cause im getting bloody married so i need all the money i can get. I work in a garage so do you think i should get the CO mixture set back to where it is. Im a bit pissed off with that so called bloke who works on proformance cars. At the end of the day i dont wanna damage my car/engine. I must admit when im driving the car there is bits of black soot on the back bumper and lights.
Old 25-02-2008, 06:10 PM
A CO of around 2.5% is commonly used to good effect even on std ones.
If chipped(?) then set to what chip writer specifies.
Good luck with the wedding!!
Old 25-02-2008, 07:00 PM
Sorry i should of said. My car has a stage 2 chip running green injectors. Its got a dyno graph from a few years ago and it had 300 bhp. I couldnt tell you what chip it is though. It might sound awful but i carnt wait till the wedding is over so that we can stop stressing,and the most important one is im gonna spend some money on my cossie. I want it setting up eventually.
Old 26-02-2008, 09:22 AM
rog
rog's Avatar
Might be worth checking the coolant sensor while your at it too....
Old 26-02-2008, 09:12 PM
ROG i changed that over a year ago. Ive asked this question about the co mixture on my car a few times and i carnt seem to get a good answer. If its chipped will it be ok if the engine is running rich? Should i just get it set to where it should be. I can soon put it on the emissions tester at work. I just wanna look after my engine/car.
Old 27-02-2008, 05:52 AM
The reason you can't get a straight answer is because it depends on who mapped the chip, as to what CO should be, just take it to a RR after setting to 2.5%, as I said this is a genarally used figure.
IMO this is tupidly and unecessarily rich, but shows the limitations of the crap ecu's these use, hence why I just bought a emerald ecu.
Old 27-02-2008, 06:22 AM
Like ive said i wanna get it set up but its not gonna be till after june time(after the wedding). So i might get it set to where you said for the time being,just so i know its gonna be safe and not damage anything.
DixieTheKid
11
06-06-2020 11:20 AM
RSmark84
13-09-2015 01:29 PM
cozzy jeff
12-09-2015 04:32 PM
hopper350
04-09-2015 12:53 AM
muffster
13
03-09-2015 09:40 PM
Quick Reply: Disconnecting iscv
