P100 brake upgrade
Your brake discs are 240mm and have a height of 58mm.
This is the same as a lot of MK1 sierra's, so any brake kit that will fit a these will fit yours too, only you will have to have the discs redrilled for 5 stud but easy to do, but if going ally bells then even easier as drilled at time.
You could change the complete upright to a granada one, better brakes 5 stud (although different?)
P100's are great to modify as almost everything is available from one Ford or another.
