500 intercooler fitting problem
Old 04-02-2008, 04:15 PM
cossiegreg1
cossiegreg1's Avatar
Default 500 intercooler fitting problem
when i have tried to fit my cooler the threads seem to be missing from the chassis leg on the driver side. the left side went in no bother, but the right side is just a hole......
any ideas?
cheers
Old 04-02-2008, 04:16 PM
KSA-Cossie
KSA-Cossie's Avatar
Might have to put a threaded insert in then m8.
Old 04-02-2008, 04:40 PM
cossiegreg1
where do i get one of them from,how do i fit that?
Old 05-02-2008, 06:01 AM
Look on car builder solutions webbie.
They are threaded as std so presume someone has stripped it at some time.
Old 05-02-2008, 06:46 AM
Nothing is ever simple is it. I just hope you dont have to cut a bit of the chassic leg out to weld a nut in then patch/weld the hole back up.
Old 05-02-2008, 06:52 AM
Ive just been thinking. I could be wrong but can the front bumper be moved,and then but a nut in the box section where the bumper mounts sit and try and hole the nut in place(or try and weld it) so that you can mount the intercooler.like i said i could be wrong but its only a thought.
Old 05-02-2008, 11:53 AM
xr_craig
xr_craig's Avatar
I've had this before. I pulled the rubber bumper mount out and dropped a bolt through the hole, then tighted it up with a nut against it, basically leaving a stud to hold bolt your cooler up to.
Old 05-02-2008, 04:26 PM
cossiegreg1
xr craig....what do you mean by bumper mount? cos i was thinking of taking front bumper off, but the hole seems quite far away from the end of the leg. so thought it would be awkward to ge a bolt down
Tabetha,the actual leg isnt threaded, it seems to be some kind of insert inside, well on my heap of shit it is!!!
Old 05-02-2008, 04:30 PM
cossiegreg1
my first thought was to weld a nut over the existing hole (external) it would look rough but will work. i will hopefully find a solution,esp with the help off ppl in here!
Old 05-02-2008, 05:10 PM
Can you not buy one of those retracting magnets,you know the ones that look like an old tv aerial but with a magnet on the end. Then attach a nut to the magnet feed it though the hole then put the bolt in which will b holding the intercooler. Ive got one of those magnets if You wanna lend it. Cause im only down the road from you. Ive also got a bendy long tool which has little claws on the end so this could also hold the nut whiste you put the bolt in.
Old 05-02-2008, 06:30 PM
The square sections fixed to the bumper, that slides in the front crossmember go past this rearmost hole, and putting a bolt in helps to prevent bumper theft, as a long bolt actually passes throught he hole in the square section after securing i/cooler(500 one)
The std fixing is a captive insert but very shallow one.
You could weld a small plate to the car after tapping the hole you make in it first, 3mm will be plenty thick enough to tighten up suffecinetly.
Old 05-02-2008, 08:52 PM
xr_craig
xr_craig's Avatar
The rubber bit in the end of the leg mate. It was awkward admittedly but after a bit of messing about i managed it, then just held it with a spanner and tightened a nut onto it.
There's probably better ways to be honest but that was all i had to hand at the time and needed the car
Old 06-02-2008, 04:15 PM
cossiegreg1
cheers for all the help boys.I'm going to tackle it at the weekend. glenshute i got a long magnet thing which i think might do the job, if not, i might have to borrow yours !!
how do i go about removing front bumper? ive never removed the cossie one before
manuel boeckx
13
03-10-2015 02:29 PM
Dr. Ickxs
15-08-2015 11:34 AM
Michael Wisbey
14-08-2015 11:57 PM
RsS2daz
14-08-2015 05:26 AM
Quick Reply: 500 intercooler fitting problem
