Boot lock jamming!!
Old 29-01-2008, 10:36 AM
Default Boot lock jamming!!
2wd cos sapph and the boot lock jams, does anyone else have the same, seems to drag grit in when it is pushed in, take it off free it up, always the plunger bit stuck, might go 4wd flush lock on this one anyone else done that also.
Any help/tips welcome, thanks
Old 29-01-2008, 11:29 AM
rapidcossie
rapidcossie's Avatar
get at it from the inside and oil/grease/wd40 it
Old 29-01-2008, 02:45 PM
dojj
Resident Wrestling Legend
dojj's Avatar
remove it and give it loads of wd40
the grease inside the slider gets old and clogs up the push bit
you can always use the key to drag it out if it gets stuck thoguh
Old 29-01-2008, 03:38 PM
AndyPen
AndyPen's Avatar
I had the same thing tab. I bruised my hands getting the clip off etc but was well worth it. Gave it a good soaking in oil and dried it out properly. Now works a treat. Used loads of white grease when replacing it so rust is held away and that damn clip should slide over better next time I want it out!!!
Old 31-01-2008, 03:23 PM
Thanks fo the replies.
I took the lock completely apart about 1 year ago, the ONLY bit that jams is the plunger as grit jams between it and the outer body of the lock
Unfortunately I have to leave it right under a roof edge(garage) so that the crap off the roof goes over the rear of the car.
The inside is never seized only the above bits, seems when you push it in it drage more crap inside with each push, the seal is there and ok, just think I will have to keep it clean around there, by washing crap away each week.
Thanks for replies
Old 31-01-2008, 03:35 PM
timster
timster's Avatar
Blasted mine from the inside with some spray waxoil and was right ever since
boeb
09-01-2020 05:11 AM
tankybaby66
06-02-2016 02:24 PM
07-10-2015 12:56 PM
2wdsaph ben
18
02-10-2015 05:18 PM
rsguy
44
29-09-2015 03:29 PM
Quick Reply: Boot lock jamming!!
