Sapphire rear speakers - 5" or 5 1/4" ??
Old 19-01-2008, 12:14 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Default Sapphire rear speakers - 5" or 5 1/4" ??
I'm going to replace the speakers in the parcel shelf, utilising the existing units (ie grille and surround), just replacing the speaker itself and possibly the tweeter too, depending of which speaker I choose.
So, are these 5 or 5 1/4?? If I measure the speaker, it's exactly 5 1/4 from extremity to extremity of the metal casing - so does this mean it's 5 1/4 speakers??
Old 19-01-2008, 01:14 PM
1374lee
1374lee's Avatar
Default Speakers:chkd
Yes mate 5 and a quarter but u will have 2 trim the pods slighlty as the original ford speakers are an odd shape.
Old 19-01-2008, 06:20 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Default Re: Speakers:chkd
Ok cheers
Old 20-01-2008, 07:55 AM
I put MB QUART Q130KNS speakers in mine as there were none when I bought the car and they went straight in, 13cm size.
Old 02-02-2008, 05:27 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Wow yes I found that out today, lots of plastic "sawdust" later, and a few new holes drilled, I got a set of Infinity Perfect 5 1/4 to fit nicely, with tweeters, and even managed to attach the standard tensile metal bracket to the rear of the Perfects, by using a type of large plastic rawlplug and a different size bolt, so they'll fit exactly as the OE kit!
Old 02-02-2008, 05:30 PM
jemis
jemis's Avatar
Are the front door ones the same size.
Old 02-02-2008, 05:33 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Yep I put 5 1/4 Infinity Reference in the front of mine, needed to drill new holes but these are hidden by the speaker grille's, and within the outline of the original speaker grilles, so no ugliness if you put the standard kit back in.
But, the depth is limited at front, even the relatively slim speakers I used mean the door card doesn't quite fit back on 100% at the bottom. Wouldn't be able to use deep speakers like the Perfects up front.
Old 02-02-2008, 06:00 PM
1374lee
1374lee's Avatar
Default SAPPHIRE REAR SPEAKERS
Turboshed,I'm glad it worked out ok,I did say it would be a bit fidly and involving cutting the pods.
Good,all sorted then.
Glad it helped.Thanks.Lee.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Kam B
24-09-2015 10:40 AM
DPDISXR4Ti
Ford Fiesta
21-09-2015 03:51 PM
cossirob
03-09-2015 09:17 PM
Quick Reply: Sapphire rear speakers - 5" or 5 1/4" ??
