Dump valve sound, or lack of !
I just fitted a forge group a dump valve to my otherwise standard 4x4 cossie.
I was sure that the first time I let off with the car on boost it gave off a drawn out "tish" noise.
Now it only seems to make a flutter noise, which is very quiet and can only be heard with the window down.
Should this dump valve be fairly quiet ? Will it get any louder with a K&N panel filter in the airbox ? and did I just imagine that first "tish" ?
Any ideas/advice appreciated
Gary
Gary
The flutter may well be turbo chatter, muffled as you have a std airbox and filter, so suggesting the dump valve is not opening well if at all.
If you want noise fit a K&N cone filter(group a), this is what I have and it is VERY loud, I have a collins group a diaphragm dump valve, which I took apart and drilled the holes out in so they are as big as possible without it breaking, easily heard 1/8 mile away!!
Hmm, I'll try the dump valve on my friends car and see if it works on his.
Its a new dump valve so if its not working i'll just send it back for a replacement.
Cheers guys
Cheers guys
Cheers for the offer, if im struggling I'll give you a shout.
Ive never seen a black 3 door going about carnoustie, is the car on the road ?
You going to the ford day at crail on 16th march ?
Gary
Gary
Gary car,s been off the road for past 4 yrs,getting a few tweeks,lol.but will be back on the road this spring,crail was the date,butnt think it will be run in for then,so will be there in my mates frs,what colouris yor saff
cheeRS stu
cheeRS stu
07-10-2015 12:56 PM
