Fuel lines and pump rewire
Old 09-01-2008, 07:18 PM
boost mad
boost mad's Avatar
Default Fuel lines and pump rewire
I have got a fuel leak some where on my saph, problem is i cant seem to trace it. i no its coming from the middle to back of the car. I know its not the tank as i changed that when i got the car.
Anyway, im considering changing the lines whilst its off the road as they arnt looking there best anyway.
My question is, do they have to be solid ? like the originals ? if not where can i get other types and where should i take it from and too ?
One other thing, where do you rewire the pump too ? i mean how far back if that makes sence !
cheers
Old 10-01-2008, 05:05 AM
stevecossy
stevecossy's Avatar
Hi ya can get braided hoses to go from back to front but not sure where ya can buy them, ya can also still use the solid type.
To rewire the pump you are best to take a live feed straight from the battery with a 40 amp inline fuse, Then fit a 40 amp relay in the boot, use the 2 orig wires on pump as switching to the relay.
Then ya will av full battery volts at the pump at all times.
If ya check back on here someone posted pics about it.
Old 10-01-2008, 09:05 AM
DON'T use a 40 amp fuse, use 25 amp, if using blade fuse.
Use someting like 28/030 wire NOT starter cable like some do!!
Old 10-01-2008, 11:16 AM
Ryan
Ryan's Avatar
dont use 25 amp fuse either.
use 15 AMP as per original.
the pump locks out and burns @ 18AMPS.
Old 10-01-2008, 04:28 PM
Jesus I have heard some crap in my time but the "fuel pump locking out at 18amps", keep taking the drugs!!
A 15 amp fuse per orignial, is no good with mods such as listed under your car.
A std pump uses 13 amps at full load, and WILL run the risk of the fuse popping if driven at full whack, but if you don't mind this and the pump stopping and causing it to go mega lean go ahead.
For other people, the FUSE RATING BEARS ABSOLUTELY NO RELATIONSHIP TO THE POWER CONSUMED BY ANY DEVICE PLACED UPON IT.
The inportant thing is to have a fuse, of lesser rating than the cable, in case of shorting.
Fuel, pumps do not lock up, they CANNOT PHYSICALLY BE "FED" WITH TOO MUCH AMPERAGE, they consume what they consume.
Old 11-01-2008, 04:23 AM
stevecossy
stevecossy's Avatar
Ok sorry got mixed up with relay and fuse. I was thinking of using an amplifier power cable with bullet fuse, do ya think thats ok or too thick tabetha ?
Old 11-01-2008, 05:26 PM
I wouldn't waste your money on OFC, just use std wire like 28/030, about £9 for 50 metres!!
POLEVOLT.CO.UK
Old 14-01-2008, 04:16 AM
stevecossy
stevecossy's Avatar
ok cheers tab is that 28 030 gauge as work in mm over here lol. about 6mm then ?
JK12
33
26-04-2021 12:09 PM
jonfoc
16
11-09-2018 05:35 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
15
07-10-2015 03:43 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: Fuel lines and pump rewire
