changing rear springs on saff
Old 07-01-2008, 02:15 PM
Zetec_mk4_XR3i
Zetec_mk4_XR3i's Avatar
Default changing rear springs on saff
i've heard a few horror stories about changing the rear springs on the sierra - any tips?? Gonna do mine on Wednesday when i'm off.
Its a 4x4 cossie by the way
Old 07-01-2008, 02:18 PM
charlie luciano
charlie luciano's Avatar
Nothing too difficult imo, go for coilovers much better
Luciano
Old 07-01-2008, 02:43 PM
cossie0_4
cossie0_4's Avatar
did mine recently not too bad but you could do with two people as when you drop the driveshaft away from hub and try and fit spring always gets in the way plus you might need a bit a leverage but quite straightforward hope all goes well mate
Old 07-01-2008, 04:03 PM
Zetec_mk4_XR3i
do i need to remove the shafts?
Old 07-01-2008, 04:14 PM
KSA-Cossie
KSA-Cossie's Avatar
What springs did you buy , the bayjoo spec ones from mike r are shit hot m8.
Old 07-01-2008, 06:54 PM
cossie0_4
cossie0_4's Avatar
no just from the hub side you can leave them attached to the diff cheers
Old 08-01-2008, 06:24 AM
EASY, 1 man job if you use a long flat bar and GREASE it, you can slide the new spring in on this, that I s how I have done mine single handed.
Old 08-01-2008, 10:40 AM
capri280
capri280's Avatar
Easy job
jack the car up using the diff and a block of timber
then support the car on the rear beam to chassis mounting points on both sides of the car
loosen and remove the bolts that hold the rear struts in place now the rear suspension arm are flexible,prise them down and remove springs,insert new spring now put the jack under the rear arms and slowely jack all up again and refit the bolts do the same for the other side
thats it unless i missed something
stu-bee99 (15-02-2022)
Old 08-01-2008, 12:00 PM
Zetec_mk4_XR3i
cheers for all replies
KSA - there was a full Koni kit on the boot when i bought the car that prev owner had not fitted yet....however it turns out the fronts are 2wd so just puttin the springs on the now till i can afford shocks
Old 08-01-2008, 07:50 PM
I did lowering springs on my old sierra hatch back and i thought it was a bit of a chew on. I had to cut the flexy brake pipe brackets off the suspension arms remove the bolts from the rear axle and use big long bars to lever the rest of the suspension down to get the springs in and out.
29-08-2015 08:16 PM
cameron2
25-08-2015 07:18 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: changing rear springs on saff
