modified rear beam
Old 26-12-2007, 02:44 PM
coachworz
coachworz's Avatar
Default modified rear beam
hi,
have anyone use Adrenaline rear beam kit? any feedback?thanks
Old 26-12-2007, 04:07 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Yes have a Stage 3 beam fitted with solid mounts and totally changed the car on the road
Doing track day at Donington tomorrow so will give you some more feedback as did Donington this time last year so will be a good comparison for you
Old 27-12-2007, 12:17 AM
RWD_cossie_wil
RWD_cossie_wil's Avatar
Mine is being made at the moment, so I will let you know as soon as it is fitted and ready, but they are reported to transform the car...Richie, got a few more thoughts on how/why its better mate?
Old 27-12-2007, 12:28 AM
the saint
the saint's Avatar
what sort of coin are we talking about here guys as this is something i will want to get later once the cars running ect
Old 27-12-2007, 04:15 AM
I too am interested, any piccies anyone ?
Am currently, when I have the time going to make a set of arms that are camber and toe adjustable, as it is very easy on these.
Old 28-12-2007, 06:53 AM
oohogwash1
oohogwash1's Avatar
I am nearly done with modifying my rear beam to take group A style adjustable trailing arms, I am going for adjustable trailing arms mainly because I have some group A cars to go off. They cars I go off use adjusters from the beam to the trailing arm. Is that what you guys are talking about ?
I am using standard trailing arms initially, later I will probably make the adjustable one so any dimensions would help me work out what to do(australia you make it or do without on a lot of stuff) On the standard trailing arm I am strengthening the shock mount area so that I can run adjustable anti roll bar from that point (using coilovers ). Again this is mainly following the cars I have access to rather what you guys are doing may well be much better...
Am I of the track, as I mentioned, your discussion sounds a bit different to what I am doing...
Another problem I have is finding some reasonably (is that cheap) adjustable blades for the sway bar... and a choiice of sway bars.. does anyone know of such a source... Or will I have to make those too
Regards
Gavan
jessie_rs
62
06-08-2019 09:27 PM
yatta
21-05-2016 10:31 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
Quick Reply: modified rear beam
