front ARB relocation with compression strut
I'm actuallu looking for the wonderfull compression strut from compbrake
very nice
but I like to keep an ARB
my solution is to relocate a custom ARB in the front
and use end links fitted on the TCA
2 solutions :
-use the ARB front an other car and do minor modification to use it
- ask a compagny to build the custom ARB
I search a little and find nothing
nobody do this type of modification before ??
very nice
2 solutions :
Rubber Rhino Crew
Reyland escos works well with just compression struts.
There must be other cars too??? If you 100% want one then go ahead and modify/make one but its not an easy job and would require someone with a bit of knowledge doing for it to work properly and be useful.
Dan
Dan
Originally Posted by martin-reyland
Dan
Dan
Have'nt tried it yet. but a friend of min have this setup on a sapphire, and it works just fine.. I will try the 3 different bars I have for it then weld it in stead of using the bolts..
FlashRS
13
31-08-2015 06:02 PM
155lee
14-08-2015 11:21 AM
