cossie spark plugs mm?
16-12-2007, 05:35 PM
hi,how must be, 0.7mm or 1mm?thanks
16-12-2007, 05:55 PM
16-12-2007, 06:25 PM
Quote:
Originally Posted by KSA-Cossie
Chipped or standard m8 ?
chipped stage 2
16-12-2007, 07:30 PM
My one on greens stg3 ran with them gapped at 0.6mm was hitting 1.6bar
0.6mm on mine at 2 bar boost m8.
16-12-2007, 08:15 PM
Live long and prosper!!
0.6 for me too
16-12-2007, 08:48 PM
is there not a small differance with waht coil your useing ? gary
16-12-2007, 09:57 PM
which type of spark plugs you use?
16-12-2007, 10:46 PM
You have just opened a can of worms LOL
I used PP8 Denso(escort cos plug)
I now use iriduim plugs form MSD
Paul
17-12-2007, 04:53 AM
After stg 1 ya do need uprated plugs and as above its personnel pref realy on which type. 0.6 mm gap seems to work well. I run 1.3 bar boost with group A coil and race plugs at 0.6mm gap with no probs.
17-12-2007, 07:49 AM
I use a 0.6mm gap with a group a coil, make sure you use the correct plug, it is far more important, I use AGPR12PP8 in up to and including stage 1, but above that a lot of people use 071's, but I use IK31's as they are much better, don't forget some decent leads too, such as MAGNECOR.
21-12-2007, 06:01 PM
i was told some ngk r's after being told they were £20 each i got scared
21-12-2007, 09:13 PM
Motorcraft 071's.
21-12-2007, 09:15 PM
0.6 on Coil
0.7-0.75 on Coil Pack.
Running 071 and throw your PP8s away
22-12-2007, 07:50 AM
I use IK31 and the shits keep fouling even with spot on fuelling!!
I think it is me driving it too easy to be honest as I never go over 2000rpm in the city where I can be for 3/4 hours!!
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
