Uprights / stub axles 3 door vs 4wd vs Saph
Old 14-12-2007, 04:21 PM
Char1ie
Char1ie's Avatar
Default Uprights / stub axles 3 door vs 4wd vs Saph
Greetings, I had a recommendation from a Ford expert about changing my Sapphire's uprights (front stub axles) to 3 door items to aid handling. I guess they have slightly different camber.
Does anybody have pictures of the two? Or know what the difference is? Have any Sapphire owners changed to 3 door uprights?
Thanks all,
Charlie
Old 15-12-2007, 07:15 AM
The camber is the same on both, the CASTOR is different on the 3 door hubs, they having a bit less, so you get better turn in, makes the car twitchier.
They also have a different lower TCA fixing so will need new arms as well.
Not worth doing, as to do the same make a spacer to go on the end of the roll bar through the TCA, before the TCA goes on and it does the same thing by pushing the wheel forward.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
gcfcos
88
15-09-2015 03:48 PM
dojj
28
11-09-2015 10:00 PM
rsstav
07-09-2015 04:43 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: Uprights / stub axles 3 door vs 4wd vs Saph
