start problem
Old 12-12-2007, 01:40 PM
tommeke
tommeke's Avatar
Default start problem
hello,
I've a standard 2wd sierra saph cosworth
since a few week's I have some starting problems
whem I drive the car for example 30 min. so he's hot and I stop it and turn it off.... then 5min later I want to start the car again but it won't go!!
the start motor works (turns) and I hear the feul pump working, but the engine won't go turn on
when I do this 10 times the engine finaly turn on, but sometimes I've to wait some minutes...
When I start the car in the morning for the first time it starts perfect from the first try! and when I wait a fwew hours it olso no problem....
I don't now what can be the problem...
Have change the ECU but nothing... the fuse box looks also OK ....
Hase anyone some suggestions?
greetz tom,
Old 12-12-2007, 04:54 PM
I had a similar fault with my saff 4x4 cossie. When it was getting warm and driving along it would just cut out leave it for about 5/10 mins and then it would start. I changed the fuel filter cause it was full of black crap. Can you hear the fuel pump relay and ecu relay clicking when your trying to turn the engine over.It might even be a faulty coolent temp sensor.
Old 13-12-2007, 04:30 AM
stevecossy
stevecossy's Avatar
As above i had similar prob, usually its cured with ECT sensor but mine was the fuel pump not giving enough pressure and also the filter was full of black crap. Good luck.
Old 13-12-2007, 11:03 AM
tommeke
tommeke's Avatar
ok, thanx
I'm going to check the fuel filter this weekend and maybe change ECT sensor
cheers tom,
Old 13-12-2007, 02:54 PM
If the ETC sensor is faulting it could be putting to much fuel in the engine or not enough. But if it was putting to much fuel in i think you might be able to smell it. My cossie came with a full service history but the fuel filter had never been changed. It had a date stamped on the side from june 1992.
Old 13-12-2007, 06:00 PM
Any look with your car then mate.
Old 14-12-2007, 05:18 AM
When it does not start you need to see if it is sparking ?, it is most likely a dodgy joint but could be lots of places.
The fuel filter will not stop it from starting like this, it would have more impact when cold as fuel flow is higher, but you would also have loss of bottom end power big time, would be ok on boost but lacking bottom end power all the time and come in with a wallop.
Old 15-12-2007, 03:37 PM
tommeke
tommeke's Avatar
change the ETC sensor today... let's hope it will go beter in the future week
fuel filter looks ok, no black shit in it,
let's hope
Old 15-12-2007, 04:38 PM
Or well fingers crossed mate. Hope it goes ok for you mate.
Johnsie
Ford Focus ST
08-09-2015 02:39 PM
muffster
13
03-09-2015 09:40 PM
nick8saff
16-08-2015 05:35 PM
Sjieter
05-08-2015 09:47 PM
Quick Reply: start problem
