phase sensor and idle valve
Old 10-12-2007, 05:54 PM
mr_intex
mr_intex's Avatar
Default phase sensor and idle valve
i have changed my phase sensor today and rotor arm and distributor cap.
i have also cleaned my idle speed control valve - i took it off, cleaned it with brake cleaning fluid (all black shit poured out!) and re-oiled with wd-40.
everything is now back in place and when i start the car it judders and will not rev very well at all. there seems to be no power at all.
can anyone help me?!
many thanks
Old 10-12-2007, 08:04 PM
mr_intex
mr_intex's Avatar
please someone!!!
Old 11-12-2007, 04:25 AM
stevecossy
stevecossy's Avatar
Did you set the gap correct on the phase sensor and also put the plug on the rite way? not taking the piss its easy done.
Double check that ya put the leads on in the rite order etc.
You could try and unplug isv to see if it changes the prob.
Old 11-12-2007, 06:15 AM
If you have removed the dizzy to do the phase sensor, check it's alignment, as just one (belt) tooth out will cause mayhem.
The notch on which the rotor arm goes needs to be EXACTLY in line with the scribe mark on dizzy body with cams and LUG on pulley all at TDC.
NOTE, the LUG on the bottom pulley is TDC and NOT the groove.
Old 11-12-2007, 07:28 PM
mr_intex
mr_intex's Avatar
i have set the gap so that is touches the distributor lobes as it turns. i have since learned that the gap should be 0.2mm to 0.3mm.
so would this be my problem?
if you guys think so i will set the gap correctly on thursday.
thanks
Old 11-12-2007, 08:03 PM
Miller 3
Miller 3's Avatar
thanks
Touches
As said should be like fag paper gap but not touching. Hopefully you have not damaged it fella
Old 11-12-2007, 09:31 PM
mechanic28
mechanic28's Avatar
yes it hs to be gapped right fella did u get your cap from fords??
Old 11-12-2007, 09:56 PM
mr_intex
mr_intex's Avatar
i do everything from ebay as i have my own business on there.
Old 12-12-2007, 04:03 AM
stevecossy
stevecossy's Avatar
As above must have the gap mate. This could be the problem just hope it not damaged owt. Best to have ford cap and rotor 2, as buy cheap buy twice on these senitive cars. Good luck
Old 12-12-2007, 10:19 AM
Miller 3
Miller 3's Avatar
I would get all your sensors from here http://stores.ebay.co.uk/Matt-Lewis-...Q3amesstQQtZkm
Old 12-12-2007, 06:55 PM
mr_intex
mr_intex's Avatar
that link is where i buy many cosworth items from.
Old 14-12-2007, 08:12 PM
mr_intex
mr_intex's Avatar
thank you everyone for all your help.
i will be setting up the fueling and idle speed on tuesday.
thanks
DixieTheKid
11
06-06-2020 11:20 AM
15
07-10-2015 03:43 PM
Chas
05-10-2015 07:13 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
routemaster
07-09-2015 05:27 PM
Quick Reply: phase sensor and idle valve
