Bd16 cams
Bd16 cams
Just bought a set of kent bd16 cams. What numbers should be stamped on them. How can you tell the difference between inlet/outlet.
I havnt measured them but the seem to have less lift than the standard ones?
one cam will have a groove inbetween the lobs and one will be solid (cant remember which is which )
if theyre bd16`s then they should have bd16 stamped on the ends of both cams
kcw means they are indeed a kent cam mate
go onto there website and you`ll find out all the specs ect you`ll need to know
i`m not cam expert mate but i`m sure theres several on here that can help
here is the list from kent cams , but you do not have bd16 cams - lift and duration is differnt ,
bd16-
Race 3500-8500 lift= 10.13 duration 265 Deg phaseing 28/57 60/25
kcw2
Sports ' R ' 2000-7000 lift=8.94 duration 263 Deg phaseing 16/67 62/21
kcw4 is the closest to a bd 16 so you dont have what you wanted
your kcw2 is a very close match to a bd 14 , hope this helps
bd16-
kcw2
Mc5506
05-10-2015 09:57 PM
