Cossie poly bushes!
Location: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Would the reason not to repalce the trailing arms with poly bushes, because that the trailing are are fitted with spherical bearings not rubber bushes?
So if the bearings are damaged eg too much play then replace them with standard items not poly bushes.
Bruce
Bruce
Re: Cossie poly bushes!
Originally Posted by cameron2
What part of a saff is recommended NOT to polybush? Rear arms? Why?
I have always poly'd the rear arms, yet to find a arm with a bearing in it!!
Never not once had any trouble bushing here, but on the beam had masses of trouble with poly here, ie way too much vinration.
DavidK
27-09-2015 02:55 PM
