cossy fuel pump
cossy fuel pump
i have just been out in my saph 2wd and it just stopped and wouldnt restart so thought it was out of petrol so put some in and still wouldnt start checked for a spark and there is 1 there how would you check fuel pump is working and that there is fuel there any help much apreciated cheers
You should be able to hear the pump priming when ya turn ignition on, or get a mate to check if ya getting power to the pump while your cranking her over. It could be the relay if not working.
Check all the fuses and connections also maybe worth checking fuel cut off switch in the boot. good luck.
It is not good for pump!
If you put 1 or 2 liters to fuel tank its may be not enough, it need more...
Once I have the same problem, my pump after working whithout fuel did not start. I have checked all electrical fuel part - it was ok. Then I have put +12V to the pump from battery by separate cable and after 20-30seconds it begin to work(then I turn out that cable). I think my pump was obstructed.
where abouts the relay for the fuel pump and when you first turn ignition on i cant hear the pump i got missus to turn ignition on why i was under car near pump and all it did was a little twich so does it only start and work as your cranking also if it was fully working will it still always run when cranking.is it poss to take fuel pipe of fuel reg to see if fuel is coming through.the reason i think it is pump is that the car justed stop and when i tried to resart did nothing but turn over didnt even try and fire many thanks
i have tried the pump whilst turning engine over and it doesnt seem to work i ould have thought it wood be loud enough to hear when running???/any help where the relay for pump is cheers
I had a similar problem with mine when i first bought it, the insulating on the phase sensor wiring inside the distributor had deteriorated, causing the 2 wires to touch each other and short.
Fitted a new phase sensor, it was fine, might not be that but its worth checking??
cossie09
14-09-2015 04:21 PM
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
