Sapphire Petrol Tank & Straps & fuel cradle
Get on That!
right gonna replace the tank & straps
wheres best to get these new i know you can get after markets tanks but what about the tank straps?
also need a replacement cradle does some1 do a replacement for these?
or is it try do the best with the 1 i've got
Pattern part tanks are around £50 delivered,Ford tank £200
Try :
http://www.shopcreator.com/mall/depa...05/1/1/-/75905
Sure its a F60C tank you want,but better check that
Pump cradles go for silly money new on E-Bay,never priced them at Ford
Try :
Get on That!
thanks for that i've found a new cradle just not the clamps that hold the filter & pump in place though.
will check condition of my tank when i remove it before purchasing owt new
are all 4x4's the same? where is it best to buy a tank and all the necessary things from? my actual tank is leaking but i dont know which bits i may need (other than the tank itself0
where is the best place to purchase most parts from
The tank rusts and then leaks on the joining seams, top half/bottom half, all fuel tank bits should be still available, I got new tank from ford at iirc £190, strap around £10-15 and pump cradle is about £90
Luciano
Luciano
thank you
JK12
33
26-04-2021 12:09 PM
