sierra fuel tank
sierra fuel tank
Hi chaps, I've got a saff cossie 1988 and the fuel tank has a big hole in it! Can anyone tell me whether the fuel tank is the same as the normal injection sierras or a part number would be good!
cheers
cheers
Different to DOHC injection Sierras m8
Can get brand new pattern part tanks for arouund Ł50 delivered to your door.
You want the tank with the small hole in the top,50mm IIRC,just for the fuel gauge sender,not the tank with the 100mm IIRC hole in the top which is for the fuel pump/gauge combined
Got mine from here:
http://www.shopcreator.com/mall/depa...05/1/1/-/75905
Pretty sure the part number is F60C you want,but ring them and check m8
Got mine from here:
well if it hadnt of happened the car may not have looked like it does now as because it was broke i started fucking around with it on the driveway and now its a T4 turbo track car i did originally buy it to use and keep standardish power for a while
Originally Posted by matt4
my one is a 92-93 4x4 cosworth sapphire, i dont know which tank is the right one, anybody recommend one for me?
can someone tell me where to get one for the 4x4 model please
Originally Posted by cossiematt
got one from the link above, fitted it this morning, top stuff
is it the F60C or F60D for a late 4x4?
i ask because the thread starter has an 88 2wd and im not sure if both are the same, i dont want to make the same mistake again
MATT4
as far as I know, there are 2 different fuel injection Sierra tanks
only one type was used on cossies
as said above, the early (cossie) type has the small level sender hole
the later (non-cossie) type has the larger level sender hole
from the link above, if the photo is correct, then F60D appears to be the later (wrong) type
F60C is the one m8
F60C is the one m8
F60C has never been shown on that web-site m8
Only reason I know its that part number is cause they sent me the wrong one to start with(F60D),so rang them and they had the measurements/how many pipes etc were on tank and worked out it was the F60C for the Cosworth
one more thing..... do you remember the price?
Just give them a call, they were more than helpful when I spoke to them
I counddn't see the F60C on the site either so the did it over the phone
Originally Posted by Xen
Would the F60D fit a late saph cosworth 4x4 ? Looking for a new fuel tank for a friend, but can't find one.
F60C for all Saph Cosworths,they all run the same gravity fed fuel pump
Rally nut
http://www.icegroupadmin.co.uk/north....php?make=Ford
So I more belive the guys who bought the fuel tanks and fitted them, but sounds strange.
None of the descriptions on there states Cosworth though
Use these people:
http://www.shopcreator.com/mall/depa.../1/-/-/-/title
F60C is the one you want,not shown on website though
Use these people:
Orig ones didn't have a swirl pot as such just some type of baffle thing,pretty sure swirl pots are only on cars with lift pumps,Saph Cos is gravity fed
steerfromdarear
28
29-01-2016 06:14 PM
ekjim
17-08-2015 08:57 PM
