abs sensors
Originally Posted by fordrs
cheers guys will look into getting from ford if not breakers thanks
Hi all,
Found this site that do ABS sensors for most cars, may help save a few quid..
http://www.atozmotorspares.co.uk/SIE...090_12092.html
Mike
Mike
Yeah I was thinking that myself.
I found the site when I was the Registrar for the 4x4 Saphs for the RSOC, thought it would be a good idea to try and source parts from other places incase Ford stopped making them.
Glad to be of assistance.
Mike
Mike
Resident Wrestling Legend
the fronts are all the same across the seirra range
if you get an upto 91 granada they are also the same on them
same goes for the rears
after 92 though the granada's get different plugs on the ends, same with the escos ones
front and rears are different though
the off side refers to the side that is not next to the kerb, so for us the off side is the drivers side as when you sit in the car you are on the right hand side
the near side is nearest to the kerb so as a passenger in a right hand drive car you would be on the near side
this doens't matter with the sensors
the granada ones are the same but they have an extra bit of suppresion on them to counter the extra electrics they have in the higher spec cars over the sierra's
