Saff 4x4 gearbox whine
Old 16-11-2007, 05:11 PM
Default Saff 4x4 gearbox whine
Hi there all. Ive got a whining noise in first gear when im pulling away put the rest of the gears are ok. What causes the noise. Do you think if i change the gearbox oil it will make a difference. Or is the gearbox fooked.
Old 16-11-2007, 05:30 PM
dojj
Resident Wrestling Legend
dojj's Avatar
make sure there is the correct oil in there first
it's specific for the mt75 and it's not the same as what ford now tell you it is
Old 16-11-2007, 07:41 PM
Bullett
Bullett's Avatar
may just need a top up or new oil,if its fooked i have an mt75 from a 4x4 for sale
Old 17-11-2007, 07:57 AM
What grade of oil do u use in them. Can you use 75/90 semi synthetic. If not what is the special oil that people use then.
Old 17-11-2007, 09:48 AM
KSA-Cossie
KSA-Cossie's Avatar
I used 75/90 synthetic stuff and the box whined so put ford stuff back in and it was fine again.
Old 17-11-2007, 03:08 PM
Sweet what is the ford oil you used then.
Old 17-11-2007, 03:13 PM
KSA-Cossie
KSA-Cossie's Avatar
I cant remember m8 i know it's specific for the mt75.
Old 20-11-2007, 10:51 PM
Jimboxr4x4
Jimboxr4x4's Avatar
Castrol FMT if I recall. Specifically for ford boxes.
Old 21-11-2007, 06:46 AM
I will have to have a look up at the ford dealer and see if they can get me some.
Old 21-11-2007, 08:39 AM
silky16v
Get on That!
silky16v's Avatar
Castrol SMX-S available from the ford dealer
Old 23-11-2007, 02:02 PM
Cossy Mike
Cossy Mike's Avatar
It's available from ford I have a couple of bottles spare (not for sale). Its called
MT75 5-speed transmission oil, and that's exactly what it says on the bottle. White bottle blue print and writing DONT PUT ANYTHING ELSE in it.
hope this helps.
Old 23-11-2007, 06:06 PM
Thanks very much people i will make a note of it and try and get some. Does anyone know which ones are the drain and filler hole.
Old 23-11-2007, 06:20 PM
Cossy Mike
Cossy Mike's Avatar
erm drain is the lowest and fill its the highest. needs a torx bit if I remember right. It's the torx screw at about 1pm on a clock if your looking at the box from under the car towards the front.
Old 23-11-2007, 06:31 PM
Comic i know the drain is gonna be the lower one but nice one hee hee
Old 23-11-2007, 07:47 PM
dojj
dojj's Avatar
there was a topic just like this only the other day with pics and stuff on it
everything is visable from the passenger side
Old 24-11-2007, 09:20 AM
Sweet thank you. I will have a look when i put it on a ramp at work.
mjonathan24
29-10-2015 10:39 PM
cossie330
07-10-2015 08:22 PM
IainRS1700T
25-09-2015 06:44 AM
Ronnie Scott
20-09-2015 10:21 PM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: Saff 4x4 gearbox whine
