2wd cosworth diff ????
recently the diff on my 2wd has started to grumble a bit when its on over run? there is no wine or any noise wile it is under load, now i a gussing that this is a worn bearing? is it posible to replace just a bearing set or is it posible it could be something more serious?? if i went to a quaif diff would this solve the problem or would i still have the grumbeling on over run? if i fitted the quaif on its own ? thanks guys any help will be great
happened in my transit thats all
you could have play in the diff, best to jack the back end of the car up and turn the shafts, including prop and see where the play is
if no play, then it'll be internal, so rebuild time
09-10-2015 07:38 PM
rog
04-09-2015 12:10 PM
FlashRS
13
31-08-2015 06:02 PM
