Co adjustment help needed
I have a 91 saff 4x4 cossy red top, its running stage 3 on greens.
Had a prob which is now fixed but want to check/ adjust Co, im told differant things. Some say set it to 1-2% on idle others say between 3-5 so im not sure now and need some help.
Maybe i can see what shes at and then take readings over various rev positions to see if it goes weak or rich, worried if wrong i hole a piston if weak or bore wash on idle if rich. Cheers for any help. Steve
OCD Victim
Another option could be to go closed-loop. Much better, guaranteed pass on MOT for emissions (provided lambda sensor is functioning) and SO much better reponse and general driving.
Ok cheers. When i raised the revs it went to 0.8% at 1st then as i raised revs more it seems to richen itself up. Suppose i should take it on the rollers 4 a proper set up.
Originally Posted by JTECHSAFF
or get a wideband on it you cant simulate boost fueling without making boost needs to be it done on the rollers or on road
thanks!
jessie_rs
11
03-06-2019 04:57 PM
kosienutter
31
22-08-2015 09:55 AM
rsstav
Ford Focus RS Parts for Sale.
16-08-2015 08:38 AM
