Autronic SM4 on YBG
Autronic SM4 on YBG
Hi guys,
I'd like to know if someone out there has fitted an autronic SM4 ecu on a nasty cossie, cause i have just bought one for my 4wd sapp cossie! and would like to know how your engines are doing! How about performance?
Reliability? keeping in mind that if you have the combination of these two, you must get it mapped my a mapping specialist!
Many thanks
Paul.
Many thanks
Paul.
It's a very good aftermarket stand alone ECU.
But, if you fit an Autronic system on an YB and you are using the std crank sensor en phase sensor, then you need to take off 2 lugs from the cranksensor....??? Always wondered why
atronic SM4 on ybg
2 lugs from the cranksensor? what does that mean? I read about autronic and find out that it can run reluctor type and hall effect crank sensor without any probs
aytronic SM4 on ybg
To all,
how much bhp does your cossie pack? what type of injectors do you run?
Are you running wasted spark? Also, what type of coil pack do use? I heard that the zetec one can produce a very good spark.
I run a zetec coilpack and have had no spark issues.
I run Rc 1000cc injectors.
The engine produces 505 bhp at the wheels, in the car on v power running 2.3 bar of boost.
Re: atronic SM4 on ybg
AFAIK Autronic can't handle the standard sequence of the triggering from an YB, so you take off 2 teeth from the crankpully, and cut off one of the phase tooth so you get one pulse per cam shaft revolution.
Regards,
Bas
Happily retired
SM4 with Autronic CDI using 4 Bosch coils.
769bhp + 200shot of Nitrous with no Spark problems.
Custom loom available from MAD to drive 4 coils, with outputs to drive Launch, Anti-lag ,Flat-shift, W/I & Nitrous.
Rod, i want a passenger ride in your saff........
SOMETIME............
Happily retired
ImaRacing 700
74
21-03-2005 09:48 PM
ImaRacing 700
107
29-01-2005 06:54 PM
