Cambelts ...
Received 1,042 Likes
I got told the gates timing belts are good. I ordered one from PJ motorsport and they supplyed me a gates belt. If your changing the timing belt you might as well change the tensioner to.
I got a Gates belt too, there was a post in general discussion some time back discussing how good Gates belts were. The end result was they were quite good.
parts supply
Stu @ M Developments
hi mate,need parts for customers race car,items listed ,can you price them and e mail them, cheers chris snell cs autos,leeds,
ap 6 paddle x competition cover x thrust bearing
set of plug leads and cap x rotor x coil grp a or better,angled cap..
crank sensor
plenum gsk[cometic or similar]
cam cover[cometic or similar]
4 x spark plugs for 450hp [best ones ][denso,ford,ngk9s ??????????]
4wd water pump gsk
4wd thermostat housing gsk
grpa cambelt x tensioner,
new cam pulley bolts and washers,
ford oil filter 4wd,
need a supplier as we sort all sorts race cars, tel 01924892014,think you know our pal alastair wide ka , thanks ,hope you can sort us out,
crank sensor
4wd water pump gsk
Re: parts supply
crank sensor
4wd water pump gsk
crank sensor
4wd water pump gsk
