2wd axle beam
2wd axle beam
Does anyone know if a 2.0i sapphire ghia axle beam is the same as a cosworth sapphire beam.I'm not talking trailing arms ,just the beam.I think i have a twist on the trailing arm mounts on a cossy i am repairing ,and i have a 2.0i i'm breaking?
cheers
cheers
Testing the future
4x4 or 2WD. if 4x4 then yes.
if 2wd, then no. the normal sierras and the 4x4 cossie use a 7" diff, and 2wd cossies use a 7.5" diff (granada scorpio beam )
Testing the future
yep, the diff mounts are further apart on the 2wd cossie because of the bigger diff.
but i understand from the cossie manual that the beam is just a standard one from a granada scorpio (not the bug eye scorpio)
i have 1 sat in my shed but im along way from you
I removed it to fit one with all poly bushed and painted to find it was bolloxed That was off ebay
So replaced it for anther one again
If you repalce the Diff with the beam then there is no problem. I have a scorpio diff and beam in mine.. had to change the arms out though because they push the wheels out another inch or two on each side.
originaly I had the smaller rear end with drums. swapped that for a rear end from a wagon (lower gears, and disc brakes). now its got the scorpio rear in it. Later I plan on swapping in a cos24v rear end.
From what I know its the arms that get bent and the bushings that get damaged.
TF
TF
Resident Wrestling Legend
i've done loads, and loads of peole i know have dones loads of swaps as well and the granada beams complete are a direct replacement fit for the sierra
in which case the wishbones won't fit because there is no where for the struts to go
unles you've put it into another wagon
Originally Posted by need4speed00001
Yes it is 2wd,looks like a need to find a beam then...............
so its the diff mounts that are different
cheers
cheers
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
