water pump
You can use either if you've got 3 mounting holes for the thermostat housing on the head, but if using 4x4 water pump, you also need to use a 4x4 thermostat housing and 4x4 radiator hoses. Similarly for a 2wd water pump ie 2wd thermostat housing and rad hoses required.
Mark RS
12-10-2015 06:01 AM
