Boost Control
Boost Control
Hi all,
just trying to get some suggestions on boost control, I ditched the amal valve on my stage 1 cossie in favour of a bleed valve as my rolling road tuner at the time obtained better results this way.
Since going to stage 3 with all the right kit including new T34, the problem is now trying to keep the boost at a reasonable level. I have fitted a brand new .31 actuator but the boost peaks nicely then just tails right off again.
So whats the best way to go from here? My RR operator/tuner suggested a Turbosmart e boost 2 controller for close on £400 but I am a bit reluctant to go this route as I am hopeful a cheaper or better solution will present itself on this forum. Thanks.
Mike.
Mike.
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
