Loss of boost pressure
Does it take much of an air/vacuum leak to lose boost? I suspect the plenum gasket as I have the classic symptons, according to this forum, as I have hesitation/misfire under boost , soot coming out the exhaust and AFR that keeps changing and loss of boost
Get on That!
get the whole intake system pressure tested, a good test is to start car hold revs abour 2000rpm then get a can of WD40 and spray it around the area you suspect the leak you can sometimes see where the fluid id being sucked in and you also find that the revs will increase or die in some cases.
The other thing i'd check is the Map Sensor, Phase Sensor Gapping (and conditon), Crank Sensor condition and gapping also the condition of the whole ignition system
This only started happening when I fitted a T34 turbo so would think that all of the above was OK and perhaps would not contribute to a loss of boost pressure don't you think?
Get on That!
(eg: bosch 803's, 3 bar Map Sensor, ECU Chip)???
Get on That!
well double check all gapping on the sensors if in doubt replace them
check the condition of your ignition amplifier also what voltage are you getting at the fuel pump & at the ECU.
do not continue to try and drive car as it will cause damage.
also what plugs are using? and what boost pressure have you got it set at
Got Denso Iridium IK27 plugs and boost is set to "half a hole" (4mm) which is giving me 15psi. When I tighten rod, no increase in boost, have removed jet from R port on amal too.
Passion for Fords!
the system i use is a cylinder leakage tester, which normally would be used to pressure up one cylinder down the plug hole. i made a series of adaptors so i can fit this to the air filter hose, so it pressures everything from the turbo compressor housing..... it has a regulator so you can adjust the ammount of air going into the system, and has a gauge to tell you what percentage of air is being lost.
yes you always lose some through the engine valves, but the system can hold 3 bar, and leaks are easy to spot.
you will be amazed where you find leaks...and how many aswell
That sounds like a great idea but can't quite see how you can measure the percentage loss when one of the valves will be open I would assume that it would not pressurize at all because any air would be going out the valve. No, hold on it would fill the cylinder wouldn't it but it must be crucial where the crank is like TDC or somewhere when exhaust valves were closed. Am I on the right track?
Can you send your gauge over to Canada!!!!!!!!!!!!!!!lol
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
