over fueling
over fueling
hi all, my saff 4x4 has a problem... no. 3 cylinder is over fueling.
removed the injectors and switched on the ignition. no.3 is pissing out fuel
when i disconnect it from electrics it's stops..
checked voltage at injectors,,one side has battery voltage,the other side
has voltage dropping from "5"volts to "0"
on no. 3 cylinder it has full battery voltage on one side and stayes at "5"volts on the other side of the connector...
checked the plugs and for a spark and they seemed to be ok...
ANY IDEAS????????? IT'S REALY DOING MY HEAD IN
checked all the injectors, the wires to the injectors, changed the plugs,
checked the phase sensor, tempreture sensor, idle sensor, air sensor, even swoped the ecu from a friends car that was running fine...
no such luck...
HELP.....
no such luck...
HELP.....
THANKS FOR REPLYING,,, yes i checked all earth connections to and from the battery. and all connectors...inside and outside the car..
unplug the ecu and run a continuity check through the injector wires
hi all,, thanks for replying...
done that continuity check and everything seem's to be ok..
i mean i love my car. but this is realy getting to me now.
and the long weekend comming up and all....
happy days
found the problem. while checking for a good spark tonight in the dark,i had no.3 plug sitting on the rocker cover,turned the engine over and saw
a spark jump from the end of the plug lead, (where the plug sits into).
replaced the lead and everything is perfect.
now i'm going to have a shower, get in my car, and DRIVE...
didn't think a bad lead would cause the ECU to send a wrong signal to the injector...anyone have this problem before?????
