Help Fitting EECIV Throttle Body Please ?
MAD Carbon Cossie
Morning,
Hoping ya can help me !
I'm trying to fit my EECIV Throttle Body to my Swedish inlet !
Problems is the TPS & the throttle spring linkage !
The EECIV TPS is completely different to the Level 8 TPS, can I use the EECIV item or is it incompatable ?
Also when the throttle body is attached to the plenum, the linkage hits the inlet ! Any idea's ?
Cheers for your help, would be eternally grateful ! Car's booked in for Mapping at the end of the month so would like it fitted beforhand !
jb
jb
MAD Carbon Cossie
Well......
Thanks for all ya help
Think I might cracked it ! Made up a lil adaptor for the tps. Shaved down a bolt so the TPS slotted on to it nice & works (gotta be semi circle), then cut a slit in the end at the right angle & aroldited (spelling) it to the excisting TPS paddel on the EECIV throttle body !
This bit works a treat !
Then have given the throttle body to a friend who is making up a 12mm spacer so the body linkage will miss the plenium & allow me full throttle instead of absolutely none !
So if you wants pic's etc let me know, i'll post some up - again thanks for all ya help !
jb
jb
