crank sensor bracket not lining up
Hi, whilst replacing the crank sensor if found that the the center is about 2mm out of the center of the sensor. (outwards)
It is a standard bracket, and shaving of a few mm of the whole bracket seems a bit tough.
Does it really need to be deadcenter? since oe is a bit of.
(why changing? well, i tought better to change indvance in case of failure whilst having a trackday and not able to drive)
DixieTheKid
11
06-06-2020 11:20 AM
mike elsome
14-09-2015 04:08 PM
