coilovers
coilovers
i have just fitted a set of GAZ coilovers and they seem to be a bit noisy as in banging and clattery is this normal??
No they should not themselves make a sound though will get more noise due to harshness of them but from car rattles etc.
The seats should be so shaped that when weight is placed on them by the springs they slip into position, if not you can get helper springs to keep under tension even when jacked up.
thanks ill have to get it jacked up and have a nother good look i think ther rear 1s are catchin on the body though have you ever known this?
A few of my friends have had this problem on their cossies. We found the passenger side spring hits the inner arch and makes a banging/squeeking sound. No idea why its only ever the one side though
