TCAs
Old 05-10-2007, 04:24 PM
Simmo
Simmo's Avatar
Default TCAs
Is there any difference between the 2wd and 4x4 front Track Control Arms?
Old 05-10-2007, 05:29 PM
I think they are different lengths, but not 100% sure, just phone parts place to see if they have two listings.
Old 07-10-2007, 10:47 PM
scotty4130
scotty4130's Avatar
anybody know if 2wd versions are the same as standard sierra ones? A few people have mentioned they are, just wondered if anybody here could confirm? Ford want 113 + vat for each arm
Old 07-10-2007, 10:49 PM
STUCOS
STUCOS's Avatar
difrent fixing to hub,one has a pinch bolt ,one uses a nut on ball joint
cheers stu
Old 07-10-2007, 10:57 PM
Paul_RS
Paul_RS's Avatar
Is the pinch and ball joint not the difference between 3 door and the other types of cossie? The 3 door using the nut and the rest being pinch? I'm not 100% on that, its just what i've been told.
Old 08-10-2007, 06:07 AM
Yes 3 door use NUT, and other all use a pinch bolt.
2wd cossie are are the same dimensionally as normal sierra arms, but have a beefier joint, getting pattern ones, you will get cossie spec ones as they only make(QH) one arm and it has to be as ford state for cossie stength wise as listed for cossie, but cheaper just to makle them all to same spec than two seperate versions.
I have used QH arms without problems for years, but had oe ford(cossie) arms wear out in three months.
Old 08-10-2007, 07:32 AM
Vic
Vic's Avatar
Actually, I think you're wrong re. 3 doors.. i checked under mine last week and it was definately pinch bolt.
Also check out:
http://www.compbrake.co.uk/technicalTCA.htm
Old 08-10-2007, 08:00 AM
rinus_2005
rinus_2005's Avatar
my 3door is also pinchbolt. but i've also seen 3doors with nut
lenghtwise they're the same. it just depends on your hub
Old 08-10-2007, 12:37 PM
Maybe your cars are not fitted with the correct original hubs ?
All three doors that I have seen as well as the two sets of hubs bought from them were nut fastening, I cannot say 100% because of this apparent fitting issue which is correct.
Old 08-10-2007, 02:51 PM
dojj
Resident Wrestling Legend
dojj's Avatar
my 3 door had nuts not pinch bolts
yatta
21-05-2016 10:31 PM
IainRS1700T
25-09-2015 06:44 AM
Mark V8
13-09-2015 09:34 AM
mint_s2
02-09-2015 08:58 AM
bassboy
05-08-2015 08:21 AM
Quick Reply: TCAs
