Front Anti-Roll Bar Mount Nuts
Has anyone experienced one of the captive nuts for the bar mount breaking off the inside of the chassis box-section?!
The nut's still on the thread and spins pretty freely but can only just get a couple of fingers through hole to hold it!!!
Need to know if there's an easy fix or whether to just tighten back down as it is?...
Re: Front Anti-Roll Bar Mount Nuts
Ok... my bolt at the mo doesn't have a washer on it and i had to machine down a socket to fit against the mounting bracket!... so i think i'll take it out
Doing it your way will be better for tightening it down i think, especially if i can put bolt through hole from inside with a spring washer attached, giving it a better chance of holding itself inside the chassis rail!
Am i right in thinking they originally had washers?... and were 17mm?
I think the original bolts were m12 but with a 13mm head. No rings in between the bracket and the bolt.
and yes, I also have a broken nut for the front ARB
AFAIK the best way to repair it is to insert a helicoil in it. Just haven't been able to find a 12mm helicoil
If you lift the interior carpet and sound deadening including the hard glued down sound deadening around the area where the box section is...you should find a metal grate in the floor section. Cut some of this away above where the captive nut is. Mig weld the captive nut back in place, once done apply new stick on sound deadening...availble from bodyshop factors or i.c.e. shops. Well, thats based on a 3dr...saffy's should be the same if thats what youve got.
If people have trouble with threads stripping...granada arb mounting bolts are the same 13mm head but the next size up in the thread department. Drill and retap the captive nut then bolt up using granada bolts...still looks oe.
Engine Machinist
Cheers guys... some good feedback here
I'm pretty confident i can get a bolt down through the inside of the chassis rail with the nut underneath... the floor's mint so don't want to mess about with it really (although if this doesn't work that's what i'll have to do!)
The bit I said to cut away can not be seen from underneith, and once you've refitted your carpet it cant be seen from inside either. Trouble with the arb mounting bolts is that you have to lower the arb each time you want to pull out the gearbox...a cossie thats around tw decades old would have had these bolts undone and retightened so many times by now that its no wonder people are now having troubles with them tbh. I was thinking of fitting compression struts just to get over this problem alone
Resident Wrestling Legend
the grate is there for that specific purpouse from what i can tell, otherwise you woulnd't know where to cut
if the nut has come off the end of the rail and the bolt is stuck in then just cut the bolt head of and withdraw the nut assembly and weld in a new nut
and you can always put a decent bit of waxoyl into the chassis rail while you are at it and then cover it over again with a bit more matting
Anutternutter
21-08-2015 06:07 PM
track.focus'd
12-08-2015 05:53 PM
