Cosworth Fuel light
Old 02-10-2007, 08:39 PM
sideways saff
sideways saff's Avatar
Default Cosworth Fuel light
i have had my 2wd saff for a couple of years now and the low fuel light has never worked.......well the fuel gauge didn't work for a year but then jumped into life on it's own !!!!!................i am just wondering(as i can't remember from my last saff) whether the light should come on with the ignition at start up ?????? ps low washer fluid light doesn't work either, so just want to know if any one else has had similar problems to save me tracing wires etc ..
cheers in advance
Matt
Old 02-10-2007, 08:40 PM
KSA-Cossie
KSA-Cossie's Avatar
Light comes on when you put ignition on .
Old 02-10-2007, 09:00 PM
sideways saff
Cheers !!!!!!!!!!! i thought it did looks like it's going to be a long day on saturday checking these annoying little things out !!!! with a little bit of luck they might not have any bulbs in them
Old 02-10-2007, 09:03 PM
KSA-Cossie
KSA-Cossie's Avatar
Good luck m8.
Old 02-10-2007, 11:22 PM
rsvan
rsvan's Avatar
sometimes mine works, other times it flash,s along with the doors open bit
Old 03-10-2007, 06:33 AM
As said comes on with ignition and low washer fluid, flashing means by signal with these, as two are out it might pay to just oput a seperate earth there to see if that is the problem on the light panel strip.
Old 03-10-2007, 12:43 PM
Smit
The 60ft Launch King
Smit's Avatar
My computer/lights haven't worked since i've owned the car! LOL
Old 03-10-2007, 05:51 PM
AndyPen
AndyPen's Avatar
Mine had a fuel gauge / light prob - there was crap on the connections on the fuel tank - dropped it enough to get my hand in via the wheel arch and fiddled a bit - it worked for a while so next winter dropped it further and cleaned it all up. No probs since then
PS Be careful not to snap the clips - grip them well as you pull
Old 03-10-2007, 06:00 PM
TurboFlush
TurboFlush's Avatar
the fuel light for empty fuel... mine only goes on when it is empty. on my scorp anyways.
I have problems with my temp gauge and fuel gauge not working once in awhile... a good smack on the top of the dash fix's that. for a bit.
TF
Old 04-10-2007, 07:46 AM
sideways saff
cheers for all the reply's.....i am glad to see that i am not alone with these wierd faults.....and that that normally a good whack fixes things but this didn't work for this problem so i think i will have to try putting a seperate earth to the panel and go from there(that's if i take it out and it is wired up )
cheers again
Old 04-10-2007, 07:50 AM
KSA-Cossie
KSA-Cossie's Avatar
It's probably disconnected itself at the back m8.
ar4ibaldo
Ford Focus ST
18-08-2015 04:24 PM
Bailes1992
16-08-2015 07:14 PM
14-08-2015 07:29 AM
taylora1409
12-08-2015 12:06 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Cosworth Fuel light
