Would 225/35/17 Tyres Cause Rubbing Issues?
I'm going to be replacing my 205/40/17 tyres in the foreseeable future and was wondering if there would there be any rubbing issues using these tyres on a 4x4 sapphire which is lowered 10mm.
Thanks for your help.
Pete.
Pete.
Received 1,042 Likes
Ive got 215/40/17s on my cossie n if i go round corners when there is someone sat in the back,the back tyres catch on the inner arches. Also my osf tyre catches on the arch. My suspension isnt lowered i think its just the standard stuff sagging a bit.
Cake lover!
I run 235 on the back of my Saph and only get rubbing is i have alot of weight in the car and go over a big bump.
With yours being a 4x4 this makes more of a problem, as you need to run the same size tyres front and rear. You might get 225 on the front but you will need the archs rolling atleast and i expect they will still rub on the inner arch at full lock.
Back in black!
what profile are your rear tyres?
Originally Posted by Dave Ridge
I,ve got 225/35r17 on mine and they are fine, no rubbing anywhere and it is lowered slightly. Wheels are 8x17" et35. Also the tyre fits nicely on a 8" rim.
07-10-2015 12:56 PM
