smoky cossie.....advice please
Right, mate has just got a cossie but its smoking quite badly but only when you come off the throttle. There is no smoke at all on start up or normal driving ......when youve been on boost and lift off only then does it start to smoke a lot then when you go back on the throttle you get a puff too.
I think i can eliminate rings coz it would smoke all the time but not sure if its turbo or valve guides.
Any advice welcome before he spends money on the wrong bits
usual T34,greens,500 cooler......i pretty sure its turbo but want to be 100% before my mate starts spending cash.
Like i say it does not smoke at all on start up or normal driving ....only after boosting on lift off and a little during boost.
Valve/guides, what oil are you using ?, if that is too thin like castrol rs it will do this, Silkolene Pro S is the kiddie to have especially with a few miles on it.
my saff has got a new t34 500 intercooler and if you hammer it then let off mine puffs a bit of smoke and you can smell it sometimes in the car i swapped my oil from mobil 1 to millers and it made such an improvement but when i took it for mapping at norris he told me it would be the valve guides
im not that worried and not going to do anything about it until something serious decides to let go
i would try an oil change 1 st mate
cheers for that mate.....which millers do you use??
not sure whether to try millers or the silkolene now
its got to be the cheapest option so i'll do a change in the week
you do see quite alot of cossies with this puff of smoke does it use much oil,
mine does exactley the same but its had new turbo,when you put your foot down on say the motorway then take it off then as you get on the gass puuuufff
its more than just a puff though.....when we backed off it was a constant stream of smoke until we stopped.
I know most cossies smoke a bit no matter what , my old saff did a bit but this is more than just a puff, thats why we want to be sure what the prob is.
as above mate, my 4x4 saff kicks out a bit of smoke like all cossies, i find millers 10w60 works for me, a cossie will use upto 1 ltr of oil per 500 mile
