what is the best suspensions
22-09-2007, 10:43 AM
what is the best suspensions for cossi for road use (and somtime track)?
-koni
- bielstein and eibach
- avo coil
- gaz coil
i have koni actually with standard springs
22-09-2007, 11:34 AM
22-09-2007, 12:11 PM
beautiful car
22-09-2007, 12:14 PM
If you go to see Viarouge in France, i think you find the best compromise, because you can choose your settings !
22-09-2007, 04:16 PM
Ebony black Sapph Cos
20 mm with koni shocks and eibach springs , very good ride quality and 18`s
22-09-2007, 04:21 PM
i used to have konis with eiback lowering springs,handled very well but i started getting scrubing issues so changed to gaz coilovers and think they are great
22-09-2007, 07:32 PM
ok, i will try to find some springs
22-09-2007, 07:46 PM
Cake lover!
Koni's and Ahmed Track spec springs on mine. Handles loads better than it used to. The fastroad ones would be better if not doing any trackdays.
22-09-2007, 08:06 PM
thanks
where to find this springs ?
22-09-2007, 08:20 PM
I've got Gaz coilers too and I think the handling is spot on.
Rich
22-09-2007, 08:45 PM
Cake lover!
sygjim
Pm Mike Rainbird off here.
23-09-2007, 05:34 AM
I have AVO coilovers, very hardcore for the road, if road use only I would go KONI with AVO/Chassis dynamics std ride height springs.
23-09-2007, 03:03 PM
I have my car on Koni adjustable shocks /Chassis Dynamics std height springs as recommended by my Simon at Woodford Motorsport. Makes for a good road setup, with reasonable ground clearance. I Had lowered springs before and when 4 up and accelerating hard rear silencer would drag on the road!
CheeRS, Mike.
23-09-2007, 06:03 PM
so, coilover are much for strong use ?
23-09-2007, 06:37 PM
Koni's and bayjoo spec springs on mine.
24-09-2007, 11:04 AM
Last Time, Get Off PF FFS
i have the same with a chrome strut brace at the front.
handling is tip top but then this is my first cossie i am driving
01-11-2015 06:53 PM
SMILER258
28-09-2015 09:04 AM
