help mounting bailey separator
hello, I buy a bailey oil separator and mount it like that :
top :
- 1 hole goes to my oil recuperator
- I put a breather on the second hole
bottom :
- the big hole take the oil wapor (on the motor near the inlet manyfold)
- I use the second hole for the return of the oil to the bottom motor (I remove the lock nut on it)
it sames the correct mounting is :
top :
- 1 hole is connected to the oil wapor hole (under the inlet manyfold)
- second hole is connected to the top of the motor, need a hole (or not used) it depends
bottom :
- the big hole with a breather
- the second hole for the return of the oil to to the bottom motor
can you give me the correct mounting please ...
top :
bottom :
top :
bottom :
Re: help mounting bailey separator
top :
- second hole is connected to the top of the motor, need a hole (or not used) it depends *
bottom :
top :
bottom :
* The "second hole" at the top of the breather can be connected to the side of the block under the turbo instead of the top of the "motor" as shown by the fitting below :
DavidK
27-09-2015 02:55 PM
