What are these injectors?
Old 17-09-2007, 05:11 PM
Sideways_Sierra
Sideways_Sierra's Avatar
Default What are these injectors?
Are they the blues from standard 4x4 saff cos?
They are currently in my 2wd, thought it went well chasing my mates stage1 2wd
Old 17-09-2007, 05:26 PM
jon@work
jon@work's Avatar
they appear to be
Old 17-09-2007, 05:37 PM
kaedalin
kaedalin's Avatar
yeah defo 4x4 blues fella
Old 17-09-2007, 05:42 PM
Sideways_Sierra
thanks chaps/chap-esses
a nice easy mod for a standard 2wd that is
but a better mod are the greens im replacing them with
Old 17-09-2007, 09:50 PM
Nash
Cake lover!
Nash's Avatar
What are you one about? Blues are exactly the same as 2wd yellows the only difference is the colour.
The reason for the change was when the cars were new it said in the service manual change everything Yellow. Thick cunt Ford Mechanics changed the injectors! Thats what i have been told by quite a few people anyway.
Old 18-09-2007, 12:37 AM
melzieann
melzieann's Avatar
i am sure it is true, i work with a bloke who was a senior tech at ford and he told me the same thing
Old 18-09-2007, 05:42 AM
It is a load of bollocks, "change everything yellow", can't believe anyone is stupid enough to listen to this crap, let alone believe it.
Blues are defintitely NOT THE SAME AS YELLOWS the flow rate is totally different.
Yellows will flow to around 285, blues to around 390.
This is assuming a DC of around 85/90%.
The blues came in due to a software change in the ecu used on the cars so fitted with them, and is probably more to do with ford getting a bulk deal on these particular ones.
Old 18-09-2007, 08:52 AM
TurboShed
Cossiemodo
TurboShed's Avatar
Did they ever change the dipstick lol?
So, would a straight swap of injectors as mentioned above give a performance increase, or is it the placebo affect?
Old 18-09-2007, 07:10 PM
The injector only opens as and when told to by the ecu/chip.
Therefore all you will do is overfuel if you put in a larger flowing injector, it will go richer , may give a little more power but also a massive amount of engine wear, as it will be rich all the time, even when not on boost.
You absolutely must use the correct chip for the spec of the engine including the injectors, as it has been written with these in mind, to get you the best compromise between performance and mpg/emissions etc.
So no not good idea just use the correct ones for the chip.
Old 18-09-2007, 08:55 PM
Sideways_Sierra
ah a nice debate there, well im pulling them out to put greens and relating chip in there, so this should be better than the hash together it currently has !
Old 10-11-2007, 05:26 PM
series_one_rst
series_one_rst's Avatar
does anyone know the correct flow rate for the 4x4 blues. i got webber ones on mine iaw45 ithink? but cant find any specs for them.
Old 10-11-2007, 08:12 PM
mechanic28
mechanic28's Avatar
so standard 4x4 dark blue injectors r good for 390bhp???if thats the case why do people go for either greys or light blues for this power if the dark blues do the job?
Old 10-11-2007, 08:56 PM
jon@work
jon@work's Avatar
probably 390cc per min
Old 11-11-2007, 09:25 AM
sailorbob
sailorbob's Avatar
The factory fitted dark blues fitted to the 4x4 flow pretty much the same as the factory fitted yellows fitted to the 2wd.
Old 12-11-2007, 11:13 PM
series_one_rst
ok so can anyone tell me the correct flowrate?
Old 13-11-2007, 03:05 PM
jht
jht's Avatar
311cc/3bar
Old 14-11-2007, 07:55 AM
series_one_rst
Originally Posted by jht
311cc/3bar
THANKS DUDE!
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
NZWINRZ
Ford Focus RS
28-01-2020 09:24 PM
Mark_
14
16-01-2016 05:27 PM
01-11-2015 06:53 PM
Quick Reply: What are these injectors?
