recon t34
Originally Posted by TurboShed
Originally Posted by tabetha
Why do you want cut back blades ?
As it is (I assume) a cossie, you do NOT want cut back blades, unless you use a stupidly large compressor or turbine wheel to start with.
Cut back blades are NOT a performance thing as such, they are for when you want to spec a turbo to the engine more closely, ie you can use a larger turbine wheel and trim some blade if it is too large, but the next one down is too small, so it makes it in between.
You would be best deciding how much power you want, then spec from there, a decent spec T34 will run up to around 375/380 all day long, with a .48 housing and have very low lag.
It is lucky that you have a mate who has a balancing machine for doing the turbo's after upgrades repairs etc, or you could just get it done properly!!
Former Sponsor
hint of sarchasm there tabby?
lol,...
too true though
also, Ł250 for 360 rebuild AND a shaft with cutback blades is fooking cheap
but as tabby said, no need for cutback blades on a T34
Carl
Me SARCASTIC, never I did not even mention your bad spelling of the word!!
I just don't like the idea of some mate in a shed putting something together that is going to wreck someones engine!!
Russ Payne
25-09-2015 08:29 PM
