sierra sapph
Is it oil or it it fuel. When they overfuel bad the exhaust joints leak what looks like oil but its the unburned fuel.
Worth cheaking
have you had this problem pal defo comes to mind because i have had smokey exhaust smalling of fuel
Worth cheaking
Posted: Sat Sep 15, 2007 5:45 pm Post subject:
bizarre
its leaking from where the exhaust downpipe bolts to the turbo????
_________________
01253 296160
07960 935815
www.gbturbosolutions.org.uk
bizarre
_________________
01253 296160
07960 935815
yeah seems so but as robrs2 states could be unburnt fuel onli thing that sways that from fuel is its usually when engine upto running temp and get a few drips and surely fuel would ignite as it drips on exhaust and is doesnt seem to ignite ????
cheers i will have to take turbo off thinking of bringing car off road for a few weeks anyway as i dont like the smoke i am getting i know the bottom end compression is fine. wworried about the head now and turbo.... as when i had bottom end re built i just replaced stem seal and re seated the valve but no harm in stripping it off or at least having the head and cylinder compression done....
cossies eh.... joys of motoring
Oil
i would check inside your boost hoses and see if there is any trace of oil, while the intake pipe where it fits compressor housing is off check for any excess play in shaft that should tell you if its your turbo
chowfornow
14
05-01-2019 09:01 PM
DavidK
27-09-2015 02:55 PM
